P1 and P2 positions
P1 and P2 positions
Postby Pilsbury » Thu Feb 04, 2021 1:29 pm
Hi all. I’m new to cnc and obviously UCCNC. I’ve cut a few projects and am finding the software pretty intuitive.
I have my set positions configured as P1 for tool change front middle, and P2 set as homed/parked in the back left corner. I’m simply after changing this P2 to back right for convenience. I’ve searched high and low on the user manual, googled it to bits and have come to the conclusion this is above my level, which is clearly very low
Any help with idiot proof instructions is much appreciated. I repeat, idiot proof!
Pilsbury
Re: P1 and P2 positions
Postby laki » Thu Feb 04, 2021 4:56 pm
Edit macros and enter values that suit you
The values are in machine coordinates.
Park pos 1 - macro M200.txt
Park pos2 - macro M201.txt
Park pos3 - macro M202.txt
laki
Postby Pilsbury » Thu Feb 04, 2021 5:18 pm
Cheers for that laki. How do I get to edit macros?!
Pilsbury
Postby dezsoe » Thu Feb 04, 2021 6:36 pm
The macros are simple text files, use notepad or any other text editor.
Postby Pilsbury » Thu Feb 04, 2021 8:14 pm
Right, I’m getting somewhere..... what I didn’t understand was how to get to where the macros are so I can edit. I was assuming this was somewhere in the user interface, a button or option. I’ve now found them actually in the program folders.
So that first hurdle out the way, I’m into another problem. My changes don’t seem to make a difference (I am saving). In addition, the current values don’t really seem to correspond to what I’d be expecting.
P1 is set for tool change. Z axis at top position, X axis in the middle, Y axis at front. Now looking at M200, the double park values are: Z 100, X 0, Y 0
P2 is set for parked in the rear left corner with Z again at the top position. Looking at the M201 values: Z 100, X 50, Y 50. It is this P2 position I’m looking to change so the parked position is rear right. I’ve changed X to both 0 and 100 hoping to at least see some difference. But nothing changes. Still parks rear left. So at present I’ve just changed back to original values.
Pilsbury
Postby ger21 » Thu Feb 04, 2021 10:06 pm
Pilsbury wrote:
P1 is set for tool change................
P2 is set for parked in the rear left corner with Z again at the top position.....................
If you didn't know how to change them, how are you setting these?
And what do you mean by "P1 is set for tool change"?
Postby laki » Thu Feb 04, 2021 10:26 pm
The macros you need to modify are in
UCCNC \ PROFILES \ Macro_ (Your macro) folder.
laki
Postby laki » Thu Feb 04, 2021 10:29 pm
I apologize!
(Your_profile) folder
laki
Postby Pilsbury » Fri Feb 05, 2021 9:33 am
Thank you all. I got there eventually!!
My machine is now happily parked in the rear right corner. Feng Shui restored!
Pilsbury
Users browsing this forum: Majestic-12 [Bot] and 38 guests
