G31 skip is ignored in mach3
Re: G31 skip is ignored in mach3
Postby A_Camera » Mon Jan 02, 2017 7:55 pm
I am sure it works in the version I used last time. Perhaps I haven't updated to the official version and still running the test version. Don't know but sure will check tomorrow.
A_Camera
Postby cncdrive » Mon Jan 02, 2017 8:21 pm
I'm not sure if the issue is settings dependent or not, I did not have time to ask this info from my collegue today,
the only thing I know is that he reproduced the issue with Chang's .xml file and he said that he found and corrected the issue.
But again I don't know if the issue was global or settings dependent.
But I would appritiate if you guys can test the new plugin test version and let me know if it works for you.
Postby ger21 » Mon Jan 02, 2017 9:29 pm
Yes, it seems to be working now.
Postby chang » Sun Jan 08, 2017 12:05 am
Hi
My work has been busy so I finished the experiment today.
V1.007.dll seems to work well now.
If there are any problems after that, I will post it again.
Thank you very much.
..Since uccnc is not familiar yet, I will try to use it in parallel with Mach for the time being.
chang
Postby A_Camera » Sun Jan 08, 2017 12:44 pm
Just checked. My Mach3 behaves weird when probing. Some times it makes a huge jump and some times it moves the Z a bit with a command like G31 X-20 F300. It happens when the touch plate is touched. Never seen this before. My previous plugin was 1.004 and that seems to have worked.
Anyway, I make my best not to use Mach3, so it is not important for me. I can also switch back to 1.004 if I need to.
A_Camera
Postby cncdrive » Sun Jan 08, 2017 1:31 pm
Josef,
Could you please post your .xml profile file here?
Then we could debug with your settings to see what the issue is.
Users browsing this forum: Bing [Bot] and 26 guests
