screen buid error
Re: screen buid error
Postby blarkscnc » Sun Dec 11, 2016 12:55 pm
ger21 wrote:It looks like there are 9 lines missing, which means that there will be 9 images missing in the screen, if you delete them.
If you delete them, you'll probably see elements with missing or incorrect images. With the Screen editor, you can select those elements, and fins out there picture number, which should then allow you to add the images with the correct number.
Or maybe contact Stepcraft for a new copy of the file?
Thanks for the reply ger I may have to get a replacement setup file from stepcraft as you say. hmm I wonder if this is the same ger21 that helped me out on cnczone with cutting alloy?
*edit*
Ok quick update, I just tried another install on a different pc and I got the same error, this confirms the stepcraft profile file is corrupt. Thanks for the help cncdrive (and ger), I really do appreciate your time.
blarkscnc
Postby ger21 » Sun Dec 11, 2016 1:43 pm
More than likely. :)
Postby A_Camera » Sun Dec 11, 2016 3:12 pm
blarkscnc wrote:I had windows 10 on before but I wanted to run the ssd for a performance upgrade and didn't have the win 10 files to install as the machine was bought 2nd hand and didn't come with OS software.
If you have a legitimate copy of Windows 7 then you can upgrade to Windows 10. Fix the computer first, before installing any apps.
A_Camera
Postby blarkscnc » Sun Dec 11, 2016 10:17 pm
Thanks for the reply A_Camera, but I wanted to go back to windows 7 as I wasn't happy with win 10 on that machine. Everything is running fine now on the machine just the stepcraft profile problem.
blarkscnc
Postby cncdrive » Sun Dec 11, 2016 10:26 pm
I gathered the Stepcraft screen installer for you, here it is: http://www.cncdrive.com/UCCNC/Stepcraft_installer_1_2.zip
So, you can download a fresh copy to resolve the broken screenset file problem.
Postby blarkscnc » Sun Dec 11, 2016 10:29 pm
cncdrive wrote:I gathered the Stepcraft screen installer for you, here it is: http://www.cncdrive.com/UCCNC/Stepcraft_installer_1_2.zip
Wow, thank you so much cncdrive, that will save me the trouble looking for it. :D
blarkscnc
Users browsing this forum: No registered users and 34 guests
