Random "The probe sensor was active..."
Postby sebmay » Sat May 20, 2017 2:36 pm
Hello,
I had very often the popup "The probe sensor was active.." during probing cyles drived by my plugin.
I read about the XHC-HB04 pendant interference. I disconnected the XHC (i use now a xbox-360 game controller), and de-activated the plugin.
I thought i solved the problem.
I just ran a 30 probes cycle. On the 29th, i have got the message.
Weird !
Seb
sebmay
Re: Random "The probe sensor was active..."
Postby CT63 » Sat May 20, 2017 8:39 pm
Not much to work with... Need more info.
CT63
Postby sebmay » Thu May 25, 2017 10:54 am
Hello,
After investigations, it appears that the most probable cause of this reside in the stepcraft 3D touch gear.
Because i untighted the spring adjusting the sensitivity, sometimes the probe stay active after i move the head up.
I added a test before every G31 i generate : if the probe is active, a message ask the operator to reset the probe in "off" position.
I will get back here if i noticed something new.
Have a good day, and thanks for your attention.
Seb
sebmay
