Slider Bug
Slider Bug
Postby ger21 » Sun May 07, 2017 4:18 pm
The slider behavior has changed, and is not correct.
When using the Reset buttons for the override, the fields return to 100%, but the sliders move to their minimum position.
My FRO slider is set from 0%-200%, so reset should move the slider to the center, but it moves to the far left.
My SRO slider goes from 50%-100%, so the slider should move to the right on reset, but it moves to the left, or the 50% position.
Re: Slider Bug
Postby cncdrive » Sun May 07, 2017 4:57 pm
Hi Gerry,
I confirm this issue in version 1.2036 and up.
I mean this problem was created in version 1.2036 when we fixed another problem about updating the FRO and SRO DROs from macro calls, unfortunately with that fix we created this new problem which you explored now.
The good news though is that this issue was already fixed and will be OK in version 1.2038 (I see a note about the fix of this and also verified it now quickly), but that version was not yet released.
Users browsing this forum: Bing [Bot] and 12 guests
