Slave axis not working properly
Postby cat320c » Fri Aug 09, 2024 5:46 am
Today after several tests.
I came across a Big problem ..... I'll explain better.
Y axis in slave with dedicated limit switch.
I do a homing and everything is ok.
I press the physical Reset button and everything is OK.
I redo homing and everything is ok.
I jog and slave axis KO ..... does not move more .... Check the parameters and they are ok ....
What happens???
Version sw 1.2116
cat320c
Re: Slave axis not working properly
Postby richardk » Fri Aug 09, 2024 10:12 am
This bug was reported few times by various users including me. It seems to be fixed in latest version 1.2117..
richardk
Postby cat320c » Sun Aug 11, 2024 5:33 am
richardk wrote:This bug was reported few times by various users including me. It seems to be fixed in latest version 1.2117..
I downloaded and installed version 1.2117, the bug exists but is not resolved
cat320c
Postby richardk » Sun Aug 11, 2024 7:13 pm
I rechecked the problem and it really seems to be solved in 1.2117 for me. That problem was the reason I downgraded from 1.2116 to 1.2115 before however now in 1.2117 it looks it works correctly for me. Perhaps the problem is also related to some specific configuration?
richardk
Postby cat320c » Tue Aug 13, 2024 11:32 am
I check the settings, now I copied my configuration files and installed in version 1.2117. I could have made a mistake. As soon as I can I will do the tests
cat320c
