install error when installing drivers for uc100
Postby wasteofspace » Tue Jul 09, 2024 4:55 am
I get the following message when I try to use the install program for the drivers for the UC100
Load Warning - '1', hexadecimal value 0x18, is an invalid character. Line 1,position 39796. -
But, the number inside the ' ' is an up arrow, not a 1 as I have shown. I just don't know how to insert an arrow sign.
Can anybody tell me how can I get past this error?
Thank you
wasteofspace
Re: install error when installing drivers for uc100
Postby cncdrive » Wed Jul 10, 2024 6:33 pm
This error message has nothing to do with the UC100 drivers, but it is because there is an error in your Mach3 xml settings file.
The error is because you using a cracked Mach3 license key, the solution to the problem is to purchase a valid Mach3 license key or to remove the cracked license key and run Mach3 in demo mode.
Postby wasteofspace » Thu Jul 11, 2024 10:51 pm
Thank you for that, I will be having some words with the person I purchased the system from.
wasteofspace
Postby CT63 » Fri Jul 12, 2024 12:09 pm
Importers buy Chinese machine rebrand them and supply illegal Mach 3 copies as a "free" bonus to buy the machine. 99% of the Mach3 copies are cracked. I believe the Mach3 forum has posted a list of illegal sellers.
CT63
Users browsing this forum: GaryC and 1 guest
