Tangential axis soft limit
Postby CFSAB » Tue Jan 09, 2024 5:58 pm
Hi
I am testing UCCNC in demo mode; I plan to use it for a cutting table with a tangential knife.
I try to run some G-code, and it works with soft limits enabled if I have the A axis / tangential function disabled. But if I turn on the tangential function, I get a warning that I have reached the soft limit. I tried to set the axis range to -500 to 500, which came slightly longer in the G-code. So it feels like even if the tangential starts over from 0 after 360 degrees, it still reaches the soft limit.
Softlimit should be disabled for the A axis if the tangential function is activated.
Tnx!
Default.pro
(42.25 KiB) Downloaded 145 times
CFSAB
Re: Tangential axis soft limit
Postby cncdrive » Sat Jan 13, 2024 9:44 pm
We will test this out soon.
