Toolpath viewer shows Z Axis horizontally on side views
Postby iOne » Thu Nov 02, 2023 5:55 am
Hi there,
I have a very minor question RE the toolpath viewer. When loading a file the toolpath shows correctly for my machine all axes in TOP and ISO views (Z pointing UP). However, on both side views the Z Axis is shown horizontally, pointing Left or Right respectively. Is this a configuration problem, a bug or something else (like a machining standard)? This happens on both 1.2115 and the new 1.2116.
Regards,
iOne
Re: Toolpath viewer shows Z Axis horizontally on side views
Postby iOne » Fri Nov 03, 2023 4:12 am
I have attached an image RE what I am describing. I would appreciate if somebody could confirm if you see the same in your system or I need to fix something. Not big deal but it would be good to know if it is a configuration problem or a bug.
iOne
Postby heffer86 » Sat Dec 09, 2023 12:11 am
I am using an isolated port (06) on my AXBB-E. I tested it with O17 (non isolated on AXBB-E) with the same result. Do you happen to have a Lightburn file that's a bit complex that burns good for you I could try?
I have attached a Zip file with a file showing all my views. Does this help?
Pics.zip
(308.24 KiB) Downloaded 145 times
heffer86
