Soft Limit Behavior
Soft Limit Behavior
Postby valhallaCNC » Fri Oct 06, 2023 4:47 pm
Ran across this. If you use steps on any increment and run up against your soft limit it will not move until you do a reset. This happens if you have show message on soft limit checked or unchecked. Even if you OK message box, with messages enabled. Another issue if you uncheck show message option and if your close to your soft limit, and do a 1" step it will go right past soft limit, and in my case hit my hard limit switch. This is 100% repeatable. This is on screen controls, no MPG attached or plugin enabled/
Thanks Joe
valhallaCNC
Re: Soft Limit Behavior
Postby cncdrive » Fri Oct 06, 2023 6:21 pm
Please upload your profile file to let us test it.
Postby valhallaCNC » Fri Oct 06, 2023 6:37 pm
Thanks for quick response...Here you go
ValhallaCNC.pro
(40.95 KiB) Downloaded 280 times
valhallaCNC
Postby cncdrive » Fri Oct 06, 2023 7:43 pm
Dezsoe, please test this and inform me.
Postby dezsoe » Mon Oct 09, 2023 8:19 am
It's the same here, I could reproduce both issues.
Postby cncdrive » Tue Oct 10, 2023 10:18 pm
We working on fixing this now.
Postby Battwell » Mon Oct 16, 2023 6:58 pm
same with wireless mpg
if you hit soft limit movement cannot be restored unless reset is pressed/released
Postby dezsoe » Mon Oct 16, 2023 9:05 pm
It is not related to the pendant, you can do it anyhow, the result is the same.
Postby Matt » Fri Feb 16, 2024 9:55 pm
Also experiencing this same quirk. The UCR201 Pendant axis movements are ignored after hitting a soft limit until a reset cycle is completed on the pendant. Ideally I would like to be able to move away from a soft limit without needing to trigger a full estop/reset as it could potentially leave an axis out of square if external forces are applied. I don't have brakes installed on all axis motors yet so once a motor is disabled the last known location isn't necessarily where the machine thinks it is. Even with a brake there's still a short unknown period where an axis could unknowingly drop or move.
Unchecking the popup option in the appearance section doesn't change this behaviour.
Should be simple enough to replicate:
- Move an axis into a soft limit using the UCR201
- Notice popup from UCCNC, machine still enabled but soft limit triggered
- Dismiss (or don't) popup from UCCNC about the soft limit
- Try to move that axis +/- using the UCR201
Matt
