minimum pwm
minimum pwm
Postby Battwell » Thu Mar 16, 2023 11:41 am
should minimum pwm always be output?
if spindle is off and minimum pwm is set at eg. 12 then pwm is output on the pin.
(low analog voltage out instead of expected zero)
correct or as designed?
Re: minimum pwm
Postby cncdrive » Sat Mar 25, 2023 3:50 pm
I think yes.
Re: minimum pwm
I think yes.
I mean if thats the minimum then it cant be less.
Re: minimum pwm
Postby ger21 » Sat Mar 25, 2023 4:04 pm
cncdrive wrote:I think yes.
He's asking if it should go to zero when the spindle is off.
Re: minimum pwm
Postby Battwell » Sun Mar 26, 2023 6:54 pm
yes ger - i would expect the pwm output to be zero if the spindle is off.
i cannot think of a scenario where the pwm would need to stay output at the minimum value.
its annoying as it shows on the display of the vfd as a frequency.
