Led 244 probe hit
Led 244 probe hit
Postby Battwell » Fri Jan 06, 2023 12:09 am
I had written a repeat probe routine that tracks led 224 probe hit
Had never noticed before but customer has!
The probe complete fails approx 1:30 times
Confirmed with stop after a failed led read.
I put the led on screen to confirm.
It doesn’t always set after a good probe.
( probe led is on and axis had stopped after probing as it should)
Weird that I have not caught this previously.
Ver 2.113
Re: Led 244 probe hit
Postby mickecarlsson » Fri Jan 06, 2023 8:27 am
Does the customer have an UCR201 pendant?
mickecarlsson
Postby Battwell » Fri Jan 06, 2023 8:37 am
No
Plug-in is disabled. ( I know that fault)
Postby ger21 » Sat Jan 07, 2023 1:56 am
I believe that this is a known bug?
Postby mickecarlsson » Sat Jan 07, 2023 8:30 am
Download and install 1.2115 with the API bug fixed:
Here is a quick fix, this is the same as version 1.2115, but with the probe bug fixed: https://drive.google.com/file/d/1grm6MutYBom9WhEVK-zEW-cyG55w1w6z/view?usp=sharing
We released it under the same software version, because there are no changes compared to 1.2115 except this fix, so only the API version changed.
mickecarlsson
Postby Battwell » Fri Feb 03, 2023 1:14 pm
macro was re written to check probe led 37. ok since.
Postby Battwell » Wed Feb 08, 2023 11:11 am
to confirm. led 244 doesnt always report correct in latest 115 version. (201 plugin fix version)
