UCCNC sometimes does not read program (comments)
Postby Rilexer » Thu Nov 10, 2022 8:05 pm
Hi
I'm trying to build 3d printer out of CNC mill, but when I load gcode generated with Prusa Slicer or Cura it cannot load a file on the comment line.
I'm getting an "Error reading line number 21 Line: ;TYPE:Custom ", but It's not even command. I get the same results for "; Skirt/Brim"
Is there a way to make it ignore all comments? It also doesn't color all of the letters in the previous.
I would be grateful for a quick response.
SM
Rilexer
Re: UCCNC sometimes does not read program (comments)
Postby dezsoe » Fri Nov 11, 2022 1:42 pm
Yes, because the comments have to be in brackets (). The semicolon ; is not part of the g-code standard and UCCNC does not use it. (Google RS274NGC for the standard.)
Printable characters and white space inside parentheses is a comment. A left parenthesis always
starts a comment. The comment ends at the first right parenthesis found thereafter. Once a left
parenthesis is placed on a line, a matching right parenthesis must appear before the end of the line.
Comments may not be nested; it is an error if a left parenthesis is found after the start of a
comment and before the end of the comment. Here is an example of a line containing a comment:
“G80 M5 (stop motion)”. Comments do not cause a machining center to do anything.
Postby Dazp1976 » Fri Nov 11, 2022 4:18 pm
Beat me to it.
(comment)
Dazp1976
Postby Rilexer » Sat Nov 12, 2022 7:42 am
Ok, I understand this standard, Fusion 360 always uses brackets in generating gcode, but all 3d printing software uses brackets.
I wonder about Stepcraft using Cura and UCCNC, which also gives semicolons and UCCNC on video ignored all of them.
https://www.youtube.com/watch?v=2SbIsb6Rq3A&t=2019s.
By the way, one short question. Is there a way to modify the inside variable in the custom M function? Like MXXX D10. Where D 10 is inside int variable
I couldn't find it anywhere in "UCCNC MACROS & SCREENSET FUNCTIONS, BUTTONS, FIELDS, LED’s & CHECKBOXES"
Rilexer
Postby dezsoe » Sat Nov 12, 2022 8:16 am
As I see they simply ignore the risk of those lines. A macro or plugin can be written to repair those files.
You should check the manual of UCCNC in the UCCNC\Documentation directory. (4.1.2 M-codes)
Postby dezsoe » Sat Nov 12, 2022 1:14 pm
OK, I wrote a little macro to convert the opened file. If you save it as M20000..M21999 then you can place a button on the screen to call it or else you can just use the MDI.
// Convert remarks
const double minimumQ = 20.0;
string fileName = exec.mainform.filenametoload;
if (!System.IO.File.Exists(fileName))
  return;
string inputFile = System.IO.Path.GetFileName(fileName);
if (inputFile == "Empty.txt")
  return;
exec.AddStatusmessage("Checking " + inputFile);
string outputPath = System.IO.Path.GetDirectoryName(fileName);
string outputFile = System.IO.Path.GetFileNameWithoutExtension(fileName) + "_(mod)" + System.IO.Path.GetExtension(fileName);
if (outputPath[outputPath.Length - 1] != '\\')
  outputPath += "\\";
String[] gCode = System.IO.File.ReadAllLines(fileName);
string line, wrk;
int ptr;
bool changed = false;
using (System.IO.StreamWriter sw = System.IO.File.CreateText(outputPath + outputFile))
  for (int i = 0; i < gCode.Length; ++i)
    line = gCode[i].Trim();
    if (line != "")
      if (line[0] == ';')
        line = line.Replace("(", "[");
        line = line.Replace(")", "]");
        line = "( " + line.Substring(1).Trim() + " )";
        changed = true;
      else
        ptr = line.IndexOf(';');
        if (ptr > 0)
          wrk = line.Substring(0, ptr);
          line = line.Substring(ptr + 1);
          line = wrk + "( " + line.Substring(1).Trim() + " )";
          changed = true;
    sw.WriteLine(line);
  sw.Close();
if (changed)
  exec.AddStatusmessage("Loading " + outputFile);
  exec.Loadfile(outputPath + outputFile);
else
  exec.AddStatusmessage("No change required");
