I have a issue where my Y axis bore probe seems to consistantly out by 0.2mm . X is always perfect.
For my setup I zero my coordinates over a hole , then I run a bore operation using the wcs in centre of bore in fusion . Bore a hole then come back and check it with my touchprobe ( I have a ITTP as well as a vers touchprobe - both exhibit the same error) using the hole probing routine .
Everytime it is out of centre only one the Y axis by 0.2mm from where the origin is when I use the hole probe .
What I have done to test
1. rerun the bore with 0.05mm bigger and it cleans up perfectly ( still using the original origin ) - so I believe no lost steps.
2. repeated probed several times rotating the probe 90 deg before each time to check if its probe pretravel errors having a effect (minimal , in the order of 0.02mm variation)
3. repeated with different probe and also rotated to check if its pretravel.
4. confirmed both probe tips are running true.
5. checked backlash on all axis - within 0.012mm
I have noticed for a while when doing a part flip my chamfers seems to be out on the Y and I have to account for the 0.2mm probed point.
So my conclusion is either fusion is moving everything by 0.2mm OR something is going on with the probe routines in uccnc ?
Looking for someone who has v2.115 and a touchprobe to do a bore operation about XY zero , then go and probe to see if they get the same result ?
