tangential blade push down speed issue
Postby girogiri » Wed Jul 06, 2022 9:59 am
Hello,
we found that when A axis is set as Rotary, if during Gcode execution feed override is changed,
the Pull Out Feed goes in accord to the Pull Out Feed parameter plus the override value while the PushDown feed is executed at G0 ... so the blade enter the material to be cut at full speed.
rgds
Giorgio
girogiri
