2112-2113-2115 axbb-e errors
Postby fandtm666 » Sun Jun 26, 2022 2:43 am
i am running an axbb-e and with 2.111 all perfect.
thought i would test the newer version due to the screen setup but i have issues with the
mist-coolant setup that use the m3-m4 relay option.
they just dont work. the spindle starts as it should when i select cw etc but when i select
mist nothing ( i use that as the relay for the vac )
fandtm666
Re: 2112-2113-2115 axbb-e errors
Postby Battwell » Wed Jun 29, 2022 3:13 pm
mist is m7
coolant is m8
not 3 and 4
Postby fandtm666 » Fri Jul 01, 2022 4:10 am
yes i understand that and tested m3 - m4 - m7 - m8 same issue
when i setup my pin allocation of pin3 port 1 to any of the m3 - 4- 7 - 8 they do not trigger the relay
when having exact same setup inputs in 2.111 it works flawlessly since the day i set it all
up. then with 2.113 -2.115 they do not work
fandtm666
