I'm using a UCR201, I think that is relevant information.
UCCNC version: 1.2112
- Code: Select all
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.OverflowException: Arithmetic operation resulted in an overflow.
at USBClassLibrary.USBClass.GetUSBDevice(UInt32 VID, UInt32 PID, List`1& ListOfDP, Boolean GetCOMPort, Nullable`1 MI)
at Plugins.PluginForm.USBPort_USBDeviceRemoved(Object sender, USBDeviceEventArgs e)
at USBClassLibrary.USBClass.ProcessWindowsMessage(Int32 Msg, IntPtr WParam, IntPtr LParam, Boolean& handled)
at Plugins.PluginForm.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4515.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
UCCNC
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/UCCNC/UCCNC.exe
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 4.8.4488.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
OpenTK
Assembly Version: 1.1.0.0
Win32 Version: 1.1.1664.6217
CodeBase: file:///C:/UCCNC/OpenTK.DLL
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
ୈỲ㬔䙸噤︬玿岱
Assembly Version: 0.0.65535.65535
OpenTK.GLControl
CodeBase: file:///C:/UCCNC/OpenTK.GLControl.DLL
OpenTK.Compatibility
CodeBase: file:///C:/UCCNC/OpenTK.Compatibility.DLL
ILCalc
Assembly Version: 0.9.7.5
p3jrwdgj
Assembly Version: 0.0.0.0
AForge.Video.DirectShow
Assembly Version: 2.2.5.0
Win32 Version: 2.2.5.0
CodeBase: file:///C:/UCCNC/AForge.Video.DirectShow.DLL
Microsoft.CSharp
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
System.Dynamic
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
Anonymously Hosted DynamicMethods Assembly
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
tmhowexp
Plugininterface
CodeBase: file:///C:/UCCNC/Plugininterface.DLL
AutoBackupProfile
Win32 Version: 1.1.0.0
CodeBase: file:///C:/UCCNC/Plugins/AutoBackupProfile.dll
AutolevelerCA
CodeBase: file:///C:/UCCNC/Plugins/AutolevelerCA.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
C76 Fault Reporting
CodeBase: file:///C:/UCCNC/Plugins/C76%20Fault%20Reporting.dll
Console
CodeBase: file:///C:/UCCNC/Plugins/Console.dll
Debugger
CodeBase: file:///C:/UCCNC/Plugins/Debugger.dll
Diagnostics
CodeBase: file:///C:/UCCNC/Plugins/Diagnostics.dll
FaultSignals
Assembly Version: 1.2.0.0
Win32 Version: 1.2.0.0
CodeBase: file:///C:/UCCNC/Plugins/FaultSignals.dll
Laserengrave
CodeBase: file:///C:/UCCNC/Plugins/Laserengrave.dll
Lubricator
CodeBase: file:///C:/UCCNC/Plugins/Lubricator.dll
Modbusmaster
Assembly Version: 1.3.0.0
Win32 Version: 1.3.0.0
CodeBase: file:///C:/UCCNC/Plugins/Modbusmaster.dll
Pinout
Assembly Version: 2.5.0.0
Win32 Version: 2.5.0.0
CodeBase: file:///C:/UCCNC/Plugins/Pinout.dll
Plugintest
CodeBase: file:///C:/UCCNC/Plugins/Plugintest.dll
Printer3D
CodeBase: file:///C:/UCCNC/Plugins/Printer3D.dll
Probing
CodeBase: file:///C:/UCCNC/Plugins/Probing.dll
Profiler
CodeBase: file:///C:/UCCNC/Plugins/Profiler.dll
Scope
CodeBase: file:///C:/UCCNC/Plugins/Scope.dll
UCCAM
CodeBase: file:///C:/UCCNC/Plugins/UCCAM.dll
UCCNC_OSK
Assembly Version: 1.7.3.0
Win32 Version: 1.7.3.0
CodeBase: file:///C:/UCCNC/Plugins/UCCNC_OSK.dll
UCR200Plugin
CodeBase: file:///C:/UCCNC/Plugins/UCR200Plugin.dll
UCR201Plugin
CodeBase: file:///C:/UCCNC/Plugins/UCR201Plugin.dll
Webcamera
CodeBase: file:///C:/UCCNC/Plugins/Webcamera.dll
Xbox360controller
CodeBase: file:///C:/UCCNC/Plugins/Xbox360controller.dll
XHC-HB04_pendant
CodeBase: file:///C:/UCCNC/Plugins/XHC-HB04_pendant.dll
knpuw40s
nnd2q2ne
lgmt3i54
omsepv5u
ciewmapo
waceqseg
plm02owc
r0r115ho
r5jv1thl
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Do you need any more info?
