Port 1 O15 display
Port 1 O15 display
Postby Nealeb » Tue May 10, 2022 6:32 pm
I have two copies of UCCNC on different machines - 2111 (existing0 and 2113 (which I am currently installing/configuring). I am confused about the labelling of Port 1 O15 on screen on 2113 as it is marked as "output" but Port 1 I15 is an input on 2111. The manual says that this is an input. The 2113 LED shows as red when the input is active, not green.
Is this just an screen display error, or have I misunderstood something?
Nealeb
Re: Port 1 O15 display
Postby ger21 » Tue May 10, 2022 7:42 pm
I believe it's just a screen error.
Postby Nealeb » Tue May 10, 2022 9:30 pm
Thanks, Gerry - I've now come to the same conclusion having checked the UCBB board and watched the LEDs! Strange error, and I was surprised that I couldn't find a reference to it when I did a quick forum search. "Fixed in next release", I expect!
Nealeb
Postby Dazp1976 » Thu May 19, 2022 12:19 am
It's worse on the UC300eth.
Ports 1,4&5 have it wrong.
Still works as input but listed as out.
Stupid interface mistake.
Dazp1976
Postby Nealeb » Thu May 19, 2022 1:17 pm
I am driving the UCBB from a UC300ETH but I wasn't sure how much of the interface varied between motion controllers in the range. I suspect that this is a "problem" that doesn't show up very often, if people notice it at all, as you are only likely to see it if you use that particular pin. In my case, I was replacing a different motion controller and had to move the connections across, and that's the pin that the wire happened to reach conveniently! I was aware that the problem might also exist on the other ports you mention but didn't bother to check details as I was working solely through the UCBB and not using ports 3/4/5. I'm not losing sleep over it and I expect it will go on the bug-fix list for a future release - can't be difficult to fix in the software!
Nealeb
Postby Dazp1976 » Thu May 19, 2022 3:21 pm
It's easy to spot in the diagnostics page.
Dazp1976
Postby Battwell » Sat May 28, 2022 8:34 am
its aready been reported.
deszoe said its been put right in the next release
