Page 1 of 3
soft limit randomly occuring, soft limits are not on
Posted:
Thu Apr 07, 2022 8:31 pm
by jwhelget
Soft limit error is stopping machine after making several passes on the same program. Soft limits are not turned on, never have been turned on. After stopping, machine can be moved in all directions. Do not know how to find which limit was reached. Has happened multiple times. Always homing on startup with switches. Restart of uccnc and or computer on previous occurrences and ran same program without moving part to completion. Last time made 2 more depth passes (same perimeter cut) before soft limit error in different position. This is new in the last week.
Re: soft limit randomly occuring, soft limits are not on
Posted:
Thu Apr 07, 2022 9:29 pm
by jwhelget
additional comments............just restarted software again motion stopped by soft limit error in yet a different position. Spindle remains running when spindle is turned off spindle retracts and y moves in positive direction while spindle is shutting down. This just occurred when end mill was deep in a cut. Very alarming. I did get a new UC100 in the last week last one was not working. Not sure if the UC100 has anything to do with this but it is a new recent factor.
Posted:
Thu Apr 07, 2022 10:49 pm
by Dazp1976
Try running the program with spindle off.
If it completes it I would say you are getting a noise issue in the wiring somewhere.
Posted:
Thu Apr 07, 2022 10:56 pm
by Delco
Do you get a screen up saying soft limits exceeded ?
Posted:
Fri Apr 08, 2022 10:40 am
by jwhelget
The attached screenshoot shows where it states soft limit reached.
Posted:
Fri Apr 08, 2022 11:09 am
by ger21
Dazp1976 wrote:Try running the program with spindle off.
Softlimits don't use wire or switches.
So softlimits is NOT checked here?
Posted:
Fri Apr 08, 2022 1:19 pm
Softlimit is as it name tells you is "software limits" is it programmed coordinates for the axes, it defines the boundaries in which the axis is allow to move.
Softlimits work only if the Enable softlimits checkbox is checked in the configuration.
Then the controller continously comparing the coordinates of the axis to the softlimits boundaries and if the axis tries to move out of that boundary then the controller stops the motion with a softlimits error.
If you not using softlimits then make sure it is disabled in the configuration at the place what Ger21 showed you.
If you using the softlimits then make sure to set the softlimits coordinates properly for your needs and also make sure to home the machine, otherwise the softlimits will not work properly because without homing your machine coordinates might not be referenced properly.
Posted:
Fri Apr 08, 2022 4:52 pm
by jwhelget
I understand the concept of soft limits. As I have previously stated soft limits have never been turned on. So why is there an error for soft limits exceeded?
Posted:
Fri Apr 08, 2022 10:29 pm
The software does not check the softlimits if it is not enabled, so I think that it is impossible that you getting softlimits error if the softlimits are disabled.
Can you please make a video of it?
Posted:
Mon Apr 11, 2022 5:48 pm
by mark68
I'm adding to this post too.
I'm just swapping over my machine from UC100 to AXBBE so as yet it's not run on the AXBBE.
I am getting a softlimits reached warning and I cannot reset becuase of it. Like above the softlimits are switched off.
I have narrowed mine down to the X Axis after turning off the axis one by one. The home limit pin is active and this is the same sensor and pin number as the limit + and -. I am seeing the hard limit light flash a little in diagnostics with the limit pins active but not with only the home pin active, which is odd. Would this cuase the trigger?
My limit switches are Normally open reed switches with two wires not wired in series.
Any advice would be good?
