Maybe I'm doing something wrong but I cannot get the analog output to work at all, I have set the variables to pin 6 and 7 for #1 and #2 but it never changes from 0v. please see the images:
Re: Analog voltage bug?
Posted: Thu Feb 03, 2022 10:33 am
by tomsmith
Also, I have checked the pins with a multi meter and the voltage never changes from 0v
Posted: Thu Feb 03, 2022 2:42 pm
by Battwell
the voltage is output on the analog pins (15 pin connector on uc300) there are 2 analog outputs available on uc300. you set a var number to the value you want. eg #7=5000 this is then output as an analog voltage. it is in the manual.
you can check/ confirm the value on the diagnostic screen (analog out)
Posted: Thu Feb 03, 2022 7:53 pm
by tomsmith
Thanks Battwell, that is what I've done, I'm using the analog port, and have tried to get an output, I have tried to set var1 and also var2 as 6,7,14,15 but cannot get a voltage on any of the pins, is it something I am doing wrong?
Posted: Thu Feb 03, 2022 10:16 pm
Attach the analog output to a #var, for example to #100 variable. Then in the UCCNC in MDI try #100 = 0 and then try #100 = 65535 These should give you 0Volts and 10Volts analog Voltage respectively.
Posted: Fri Feb 04, 2022 9:10 am
by tomsmith
Thanks CNCDRIVE, but I believe I have attached an analog output to a variable and it is still not working.
Would the image below be the correct way to do this? on the "I/O setup 1" page under "Var#-_> analog out 1", if this is correct then it is still not working
Which version of the software you running? It looks to me that it is a problem with your screenset. If you go to the screen editor and click the Analog output DROs then does the DRO gets selected? I'm suspecting that the DRO is missing from your screenset.
Posted: Fri Feb 04, 2022 1:15 pm
by tomsmith
thanks, I'm running 1.2113 and I have just downloaded it from the website again to be sure, (https://cncdrive.com/UCCNC.html) version 1.2113 also, reinstalled it but it is the very same problem, also when I check the voltage on the analog pins, it doesn't change from 0v.
