Mach3 & G31
Mach3 & G31
Postby Alberto FUL » Thu Jan 12, 2017 2:42 pm
Hello Balasz,
Mach3 V. 3.043.66, UC300ETH5LPT, Plugin 1.006 or 1.007
G91G31Z-20F300 (not supposed to trigger at this point, only approach move)
G0 X5
The axis moves but when poistion reached it freezes. If I hit the probe then it moves to next step.
Same behavior in VB script.
I have same application in other machine but UC300USB and works perfectly.
I need to catch up with my probing routine.
Thanks for help
Alberto FUL
Alberto FUL
Re: Mach3 & G31
Postby cncdrive » Thu Jan 12, 2017 3:21 pm
Will verify this asap.
Re: Mach3 & G31
Postby cncdrive » Thu Jan 12, 2017 9:21 pm
The issue with the probe with the Mach3 plugin when ran to endpoint without triggering the probe was fixed.
The problem was in both the UC400ETH and UC300ETH plugins, so I will attach both plugins for testing.
UC400ETH V1_013.dll
(297.5 KiB) Downloaded 933 times
Re: Mach3 & G31
Postby cncdrive » Thu Jan 12, 2017 9:23 pm
The UC300ETH test plugin attached here.
UC300ETH V1_008.dll
(669 KiB) Downloaded 941 times
Re: Mach3 & G31
Postby Alberto FUL » Fri Jan 13, 2017 10:55 am
Thank You very much.The V1_008 works good.
Very efficient service.
Thanks again
Alberto FUL
Users browsing this forum: Majestic-12 [Bot] and 22 guests
