It has been suggested that it is an memory issue with .NET and to downgrade to an earlier version, which you can not do in windows 10.
11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz (8 CPUs), ~2.4GHz
Installed RAM 16.0 GB (15.8 GB usable)
System type 64-bit operating system, x64-based processor
New laptop dedicated to UCCNC
Windows 10 Home 64-bit (10.0, Build 19042) (19041.vb_release.191206-1406)
.NET 4.8
The .NC file is too large for the forum upload, but I can send if you want to repro this issue with a new build\install of windows. Although the crash happens with any largish file I try.
UCCNC rumbles along till it runs out of memory.
There is another bug report 01/13/22 with this same issue "Memory leak when file is open". No resolution there either.
Log Name: Application
Source: .NET Runtime
Date: 1/20/2022 3:08:14 PM
Event ID: 1026
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Garage
Description:
Application: UCCNC.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at OpenTK.Graphics.OpenGL.GL.BufferData[[OpenTK.Vector3, OpenTK, Version=1.1.0.0, Culture=neutral, PublicKeyToken=bad199fe84eb3df4]](OpenTK.Graphics.OpenGL.BufferTarget, IntPtr, OpenTK.Vector3[], OpenTK.Graphics.OpenGL.BufferUsageHint)
at UCCNC.Makedrawing.changeverticescolor(Int32, Int32)
at UCCNC.Form1.screenrecolorcycle_real()
at UCCNC.Form1.GLtimer_Tick(System.Object, System.EventArgs)
at System.Windows.Forms.Timer.OnTick(System.EventArgs)
at System.Windows.Forms.Timer+TimerNativeWindow.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.NativeWindow.Callback(IntPtr, Int32, IntPtr, IntPtr)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG ByRef)
at System.Windows.Forms.Application+ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr, Int32, Int32)
at System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Int32, System.Windows.Forms.ApplicationContext)
at System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Int32, System.Windows.Forms.ApplicationContext)
at UCCNC.Program.Main(System.String[])
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name=".NET Runtime" />
<EventID Qualifiers="0">1026</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2022-01-20T22:08:14.8521744Z" />
<EventRecordID>2132</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>Garage</Computer>
<Security />
</System>
<EventData>
<Data>Application: UCCNC.exe
</Data>
</EventData>
</Event>
Faulting application name: UCCNC.exe, version: 1.0.0.0, time stamp: 0x5e3845b5
Faulting module name: ig12icd64.dll, version: 27.20.100.9466, time stamp: 0x6062e276
Exception code: 0xc0000005
Fault offset: 0x00000000000a2d59
Faulting process id: 0x78c
Faulting application start time: 0x01d80e369601da47
Faulting application path: C:\UCCNC\UCCNC.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_bf22c341d1c71ba2\ig12icd64.dll
Report Id: ab8953f2-ef8f-4255-a953-30f6cbb62ad2
Faulting package full name:
Faulting package-relative application ID:
