RUN and JOG Stay On After Homing
Postby Jasonrm1983 » Sun Apr 25, 2021 8:43 am
I have a UC100 with a C11G bob. When I home all everything works fine as it should for the last 2 years things have been running great! But in the last 2 months, I have had this issue after I home all and jog the y in to position it will not go back into IDLE mode and stays in RUN and JOG and I have to hit the RESET button to change any settings in the program after the JOG. I also am not able to probe because of this as I have to hit RESET. I am using the 1.2111 of UCCNC. Would love some help with the issue.
Jasonrm1983
Re: RUN and JOG Stay On After Homing
Postby cncdrive » Sun Apr 25, 2021 1:43 pm
How are you jogging? Keyboard? Isn't it possible that the key locks in?
Postby Jasonrm1983 » Sun Apr 25, 2021 5:59 pm
I am "joging" by using the mouse and jog pull out window in UCCNC. I am use a UC100 and a C11G Bob. My machine is an Z-X-Y-A(slave) setup (4x8').
Jasonrm1983
Postby Jasonrm1983 » Sun Apr 25, 2021 6:22 pm
I'm having the same issues this guy is having (his post below). The only difference is I'm having jog and run stay on. So when I home my machine it stays in idle mode as it should and the status monitor but as soon as I move any of the axes it gets stuck in running jog mode but the machine does stop moving when I let go of the mouse or keyboard. The setting menus are grayed out and I'm not able to change anything unless I hit reset, basically it locks me out.
"By Trooper11040 » Thu Jul 02, 2020 4:04 pm
So I just started using UCCNC 2 days ago, coming from GRBL prior. If I home the machine, zero out all the offset, and go to jog the machine using the continuous function, It will grey everything out, locking out my ability to save a new work zero. When I go into the status screen, it will show jog still lit up red after I am done jogging. Hope that makes sense. If a video is needed, let me know and I can upload one!"
Jasonrm1983
Postby cncdrive » Sun Apr 25, 2021 7:28 pm
No need for video, I understand your description.
But please upload your profile file so my collegue Dezsoe can test it using your settings.
Postby Jasonrm1983 » Sun Apr 25, 2021 10:12 pm
Thank you for your quick response!
Here is my Profile.
Also, When I use Mach3 (which I despise) the problem is non-existent only in UCCNC does this happen.
All versions I have tested this on are 1.2111 and 1.2113 of UCCNC and I get the same issue.
Default.pro
(37.39 KiB) Downloaded 536 times
Jasonrm1983
Postby Jasonrm1983 » Sun Apr 25, 2021 10:59 pm
So Today I did some tests. I notice when I close UCCNC the blue light on the UC100 stays on after closing the application. In mach3 it works as normal and the blue light turns off after closing mach3. Thought that would be of some help.. It's almost like the firmware hangs with UCCNC and not with Mach3 IDK.
Jasonrm1983
Postby cncdrive » Fri Apr 30, 2021 5:48 am
Yes, if the blue light remains on then the application hangs.
I have no idea why is this happening, it is not a usual thing.
Can you try it with a different computer?
Postby Gebbi » Tue Jul 27, 2021 11:32 pm
Hi.
I also have the same problem as mentioned above: jog and run stay red and the config pages are greyed out.
I´m using 1.2111 and UCC100.
Sometimes it happens immediately after homing, sometimes I can jog several minutes without problems.
The only solution is pushing "reset".
When the problem occurs and I close UCCNC, the UCCNC window disappears, but there is still a UCCNC.EXE process running in the Task Manager.
Gebbi
Postby FactoryWorks » Thu Mar 17, 2022 7:02 pm
hi, I found my way here with this exact problem and have yet to find a solution. Any updates to this?
FactoryWorks
