Z Movement after G49 Unpredictable
Postby ADuarte » Sat Mar 27, 2021 2:20 pm
I am running UCCNC Version 1.2111 with AXBBE . If I stop a program partway through the run cycle using Feedhold and then stop, I type G49 on the MDI line,
and then MDI a Z axis move (Z2.00), the machine will move to z2 and then rapid to Z.1. I can repeat the G49, and then Z2 in MDI and the machine will go to Z2 and then rapid to z.1 again. The z.1 looks like it is including the tool height offset because the position with the tool in the spindle looks about .1" above the part.
ADuarte
