Laser control
Posted: Sun Mar 14, 2021 12:31 pm
Sorry this may be down to my own ignorance.
I've recently switched from grbl to using UCCNC with a UC400eth. I have a diode laser attached to the CNC and i am using Lighburn to output gcode which i am then manually editing to use the M10Qxx and M11 commands. After some experimenting this is working pretty well. AS well as this i can control the laser using commands in the MDI.
However after completing a gcode file output using fusion360 with their UCCNC post for the router the laser stops responding to the M10 and M11 commands and only comes on full with an M3 command there is no response to M10 or M11 commands. This is fixed by restarting UCCNC. Is there an explanation for this behaviour I am missing?
Many Thanks
Many Thanks
