For probing a tool in touchplate, machine is homed not yet
Postby Vidubium1865 » Fri Jan 01, 2021 4:21 pm
Hy everybody,
i have a question about probing a tool with a touch plate. When i homed my machine and i want to set a tool to measure the right length the software tells, that my machine in not homed yet. I start a new homing and than i the probing screen i try the same with probe tool, but it tells that the machine is not homed. What i am doing wrong? I saw in a yt- video that there is the same. I tried in two versions of uccnc. In 1.2111 and 1.2112. In both is the same problem. When i try in simple probe on z it works.
Best regards
Vidubium
Vidubium1865
Re: For probing a tool in touchplate, machine is homed not y
Postby dezsoe » Fri Jan 08, 2021 8:51 am
If you have a slaved axis then update to 1.2113. This was a bug in the probing plugin and it is fixed.
Postby SBQ » Thu Feb 10, 2022 8:18 pm
I am experiencing the same issue. I do not have a slaved axis. and I am running 1.2113. the "simple probe" sequence will try to work but the "probe tool" will always return "the machine is not homed".
SBQ
