Homing ignores limit switches
Postby vdl » Mon Nov 16, 2020 6:04 pm
UCCNC version 1.2111
When homing UCCNC ignores other limit switches. If home input configuration is incorrect then machine runs past limit switches and crashes. I believe while homing it also should look on other limit switches.
Default.pro
machine profile with (now) correct homing configuration
(40.24 KiB) Downloaded 508 times
vdl
Re: Homing ignores limit switches
Postby dezsoe » Wed Nov 18, 2020 10:29 am
How was the wrong setting?
Postby vdl » Wed Nov 18, 2020 12:14 pm
Example.
I'm using limit switch as homing sensor. If i put X+ limit switch as X home sensor then machine goes past X- limit switch and crashes - it stops only when configured home sensor is triggered.
Another example. Homing X axis. While X axis is moving if i put something metalic to any of Y axis limit switches - i see Y limit switches triggering in diagnostics window, but movement is not stopped.
vdl
Postby dezsoe » Wed Nov 18, 2020 5:25 pm
OK, I see, thank you!
