Skipping M30
Skipping M30
Postby Hoop2125 » Thu Oct 22, 2020 2:47 am
I'm running version 1.2111
One profile works, the other skips the M30 macro
Hoop2125
Re: Skipping M30
Postby ger21 » Thu Oct 22, 2020 11:41 pm
Is there an M30.txt in the macro folder?
Re: Skipping M30
Postby Hoop2125 » Fri Oct 23, 2020 12:52 am
Ger, you are amazing. It is not your screen set that has the issue. I made a dumb screen set that I use for simple profile cutting. This a base profile has the issue. I copied the m200 script with some modifications into the M30, and it skipped it. I then moved the code to the M9 and now I am getting the z raise and park at the end of my program. Someone on the Facebook group said this is a known issue with this version.
Hoop2125
Users browsing this forum: Google [Bot] and 15 guests
