UCCNC crashes on certain gcode file loading (mach3 is ok)
Posted: Mon Aug 17, 2020 1:50 am
I have recently installed a UC300ETH-5LPT and UCCNC 1.2111 and when loading certain gcodes the software crashes (does so with 100% repeatability on these files) but does not crash on mach 3. The file is ~4mb, 147k lines, 2mm bit, 30 small repeated parts in an area of ~400mm x 200 mm, not 3D.
If I reduce smoothing, optimisation and the number of the parts down to 24 parts (84k lines) then it loads and cuts but the uccnc interface is very laggy and slow, including axis movement which makes it difficult to use. CPU shows ~55%.
I want to change more of our machines over from mach3 to UCCNC, but these types of files are not uncommon for me.
Any ideas? what slows the UCCNC interface and jog movements down, is it number of lines or something else?
