Pocket probing routine
Postby Delco » Wed May 06, 2020 9:17 am
Is anyone able to get the pocket probing routine to work , all fields filled in but it will not activate to enable a probe. Every other probing routine , ie simple , angle, circle inner outer and corner probes all work fine.
Delco
Re: Pocket probing routine
Postby Robertspark » Wed May 06, 2020 9:29 am
What version of uccnc?
Postby dezsoe » Wed May 06, 2020 9:29 am
Could you make a screenshot? There's no special setting. You have to enter a P1 value, fast and fine feed and fine distance.
Postby Delco » Wed May 06, 2020 10:31 am
Yep everyhting entered as per my normal probing , I have taken a screenshot of my settings - its on my home pc rather than the machine but its a cloned version with all the settings , as yes my machine is always home . Latest version 1.2112
Can anyone see if it works on thier machine , this will not even move a axis when start probe is pressed.
Delco
Postby dezsoe » Wed May 06, 2020 10:51 am
It seems to be set correctly. When you press Start probing what does it do? Any message? I've just tested the same version with your settings and it works fine.
Postby Delco » Wed May 06, 2020 11:33 pm
dezsoe wrote:It seems to be set correctly. When you press Start probing what does it do? Any message? I've just tested the same version with your settings and it works fine.
It does nothing at all ? , I deleted and reinstalled 1.2112 and it seems fine now on the same profile ???
Delco
