v1.2113 > Don't reset toolpath view on reload
Postby Robertspark » Sun May 03, 2020 10:38 am
could someone check out if setting the toolpath view is reset upon reload despite the checkbox on the appearance tab being set?
(minor issue, click one button to reset onscreen [number 141 - Toolpathviewleft - Sets the toolpath to a left side look viewing mode.]
Re: v1.2113 > Don't reset toolpath view on reload
Postby dezsoe » Mon May 04, 2020 9:40 am
It works fine here. Also tested with left view.
Postby Robertspark » Mon May 04, 2020 2:16 pm
:? nope not working here.... I'll post a youtube clip later... maybe I'm doing something wrong.... ;)
Postby Delco » Wed May 06, 2020 10:33 am
I have had a couple of instances of toolpaths not showing up on file load , ran the job fine though and next file load it was ok ??
Delco
Postby dezsoe » Wed May 06, 2020 10:53 am
Usually, the G52/G92 offsets are not shown correctly.
Postby Delco » Fri May 08, 2020 1:35 am
Have a issue today where some toolpaths load and show and others dont. , hit reload and nothing , it shows the dimensions of the job but no toolpaths . Using 2.112 , not sure if its my fusion post processor causing the issue or UNNCN not reading it properly.
Strange thing is I have a demo version clone of my uccnc setup on my desktop and the toolpath loads up and shows fine , same file will not show toolpath on my CNC though. if all files did not show toolpaths on my cnc machine I would suspect a setting wrong but most files show toolpath properly - go figure ????
Delco
Postby Robertspark » Fri May 08, 2020 7:37 am
Memory issue?.... Restart, does it clear the proble
Postby dezsoe » Fri May 08, 2020 8:38 am
Without the faulty g-code and the profile from that PC it cannot be answered.
Postby Delco » Fri May 08, 2020 9:59 am
Would you like the gcode and profile sent somewhere - both computers are running identical profiles and it it the same gcode file on a sd card put into each computer .
Only seem to have happened since I reloaded the software on the cnc machine after pocket probing routines were not working properly , up until then it always loaded the multiple toolpaths
Delco
Postby dezsoe » Fri May 08, 2020 10:34 am
That is another thing I don't understand. I can't imagine what could be changed in the probing system with a reinstall. (You can send mail to support at cncdrive dot com.)
