Router SuperPID control with UC300ETH
PostPosted: Tue Mar 10, 2020 10:57 pm
by marteng
Good day, I have driver setup comprising of 1 UC300ETH, 2 HDBB2 drivers, 6 DG4S-08020 servo drives + 1 SuperPID router speed controller.
I have been having issues with router speed control when connecting SuperPID to output4 on either of the HDBB2 drivers, as well as to the analog port on UC300ETH. Furthermore I had the firmware of UC300ETH upgraded nd gone through the whole connection and test processes once more time. Also to make sure to eliminate any possible noises I rewired SuperPID out of the system, but no results. Every time having 0 control of the router speed, except when connecting to HDBB2 rpm is always at max without possibility of varying while connected to UC300ETH speed rpm are not proportional. All collections made in every situation were located to the same board to ensure common grounding. Please advise if this is a potential bug.
Thanks Marteng
Re: Router SuperPID control with UC300ETH
PostPosted: Wed Apr 01, 2020 7:14 am
by marteng
Good morning to all, Kindly ignore the above as it turned out to be other issues not related to software!! Sorry in case I have created unnecessary commotion in any way. :oops: :oops:
