V1.2112 Reference Workpeice Safe Z issue
Postby Karnage » Sat Oct 12, 2019 4:12 am
Team,
Firstly thank you for all of you hard work and dedication to creating, enhancing and supporting a fantastic product.
I'm not sure if it's something in my settings, but i have noticed since the upgrade it seems the there is an issue with the safe Z function.
After probing the workpiece, and pressing Start Probe the Spindle travels to the Mobile Probe Pos at the initial probe height, once it arrives at the XY coordinates then moves the spindle up to safeZ then Probes the tool. After it probes the tool, the spindle returned to safe Z, moves back to the workpiece XY coordinates. at this point the spindle moves Down to initial height
it seems the order has changed to call safeZ after the XY move instead of before?
https://www.youtube.com/watch?v=40HVpj2 ... SQc-GtvG94
I've attached my Profile also.
Karnage
Re: V1.2112 Reference Workpeice Safe Z issue
Postby Karnage » Sun Oct 13, 2019 11:38 am
Current Profile attached.
CNC_Router.pro
(37.65 KiB) Downloaded 739 times
Karnage
Postby Karnage » Thu Oct 17, 2019 8:13 pm
Thanks to the Support Team, this was fixed via email.
In case anyone else comes across the same thing. In the Probe Setup -> "Greater Z is safer in G17" was not checked.
Karnage
