v12112 screen problem
Postby thegreatwaldo » Thu Oct 03, 2019 10:47 pm
Hi Balasz
I just tried the latest test version you just posted v1.2112 and in the initial movement preparation window the 2 selection buttons at the bottom of the box have the lower 2 thirds of the box missing so that you can't read the text . This is the box that comes up after run from here / cycle start.
I'm using a benq 32" 4k monitor.
Cheers
Andrew
thegreatwaldo
Re: v12112 screen problem
Postby cncdrive » Thu Oct 03, 2019 11:02 pm
Set the display settings in Windows to 100%.
Postby thegreatwaldo » Fri Oct 04, 2019 6:38 am
cncdrive wrote:Set the display settings in Windows to 100%.
Hi Balasz
Thanks that worked
Cheers
Andrew
thegreatwaldo
