I recently installed 1.2106 for the back off feature.
I have the Y axis on a master-slave configuration and from what I've seen, the back off only applies to the master.
To get the slave to back off I had to edit its own configuration. I suppose this is wrong since both should be doing back off according to the master.
Apart from this bug (?), I think, a good feature would be disabling the fields that can't be edited when an axis is a slave, just for clarity.
