Hello,
i have a with setting up some output trigger for my CNC machine.
My intention is to start the waterpump for the spindle and the aircooler
for the other electronics if spindle is running.
Port 3 Pin 2 and Port 3 Pin 3 control two relais. They are
triggered directly from UCCNC(IO Trigger) with LED 50/51
(Spindle on cw/ccw).
So settings are:
Port 3, Pin 2 <- LED50
Port 3, Pin 3 <- LED50
Port 3, Pin 2 <- LED51
Port 3, Pin 3 <- LED51
But with this Settings both Output Pins change their
Output(low - high) uncontrolable. They don‘t have a
constant state.
How can I control my two relais so that they are
active if my spindle is running?
Thanks in advance,
Christian
