Backlash compensation issue.
Postby Lobos8403 » Fri Oct 14, 2016 2:21 pm
Hello i just switched over from Mach3 and i am setting up the UCCNC software. I'm finding that when i step jog at .001 increments with backlash compensation on is giving me some unusual results. When i step more then about 5 increments in the same direction i can see the motor move in the opposite direction almost as if its applying the backlash compensation in the wrong direction. The backlash compensation should only work when changing directions. I found this as i was trying to dial in the backlash compensation numbers for the mill. Has anyone seen this before? When i turn backlash comp off the step jog goes back to normal incremental.
My setup is on a windows 7 64bit machine, with UC400ETH.
Thank you!
David.
David Villalobos
www.Lobos-Industries.com
Lobos8403
Re: Backlash compensation issue.
Postby cncdrive » Fri Oct 14, 2016 2:33 pm
Try to higher the comp.acceleration parameter of the axis. If it is high enough, e.g. like 200% then this issue should not happen.
