MDI focus issue?
MDI focus issue?
Postby ger21 » Tue Oct 04, 2016 1:29 am
1) Start UCCNC
2) Click RESET
3) Click Enter to activate MDI
4) Type in some code into the MDI
5) Now, if you hit the Enter key, the MDI command is not executed, no matter how many times you hit the Enter key.
Until you click in the MDI box with the mouse, then hit the Enter key.
Subsequent MDI operations work fine with just the enter key. But if you try it when you first start UCCNC, it doesn't accept the Enter key.
Different, but similar issue.
If you move or drag the toolpath display with the mouse, the Enter key will not activate the MDI until you click somewhere outside of the toolpath display with the mouse. Focus appears to stay with the toolpath display.
Re: MDI focus issue?
Postby mphel » Tue Oct 04, 2016 7:28 am
I've just tried this on versions 22, 23 and 24 and I get exactly as Gerry describes in all three..
Mark
mphel
Postby ger21 » Tue Oct 04, 2016 10:36 am
Both custom and default screens and profiles.
Using the latest version I believe.
Postby cncdrive » Tue Oct 04, 2016 12:02 pm
Hi Gerry,
Thanks, both issues are reproducable here, I'll correct them to next version.
