Write offset writes soft limit automatically
Posted: Tue Feb 06, 2018 12:54 am
Version 1.2047
If you set softlimit- to to "3" ,for example. AND you have soft limits enabled ...When you apply setting it will write the softlimit - value ("3) into the "Write offset on homing field".
A work around is to NOT have softlimits enabled when you click "apply settings" , that way It will keep (not overwite) the softlimit- value into the "Write offset on homing field".
HOWEVER, if at any time after the fact, you DO click "APPLY SETTINGS" while softlimits are enabled you will get an unwanted suprise of having UNCC overwite the softlimit- value into the "Write offset on homing field"
