UR201 sudden movement
Re: UR201 sudden movement
Postby Svarv » Wed Jan 01, 2025 3:57 pm
Hello
I have the same problem with my ucr201.
but I have a solution to the problem, use Safety button mode left
or right or both, dont use disable.
then it works!
I have a video of how it malfunctions,
I can email it if anyone on cncdrive wants to see how it behaves
Svarv
Postby RsX » Thu Jan 02, 2025 6:15 pm
Svarv wrote:Hello
then it works!
If you are here you'll soon find out there is a new version of UCCNC that solves about 5 years of issues.
I know because I did the same :roll:
RsX
Postby Matt » Fri Jan 03, 2025 2:29 am
RsX wrote:If you are here you'll soon find out there is a new version of UCCNC that solves about 5 years of issues.
Which version are you referring to? I downloaded one from the forum a few weeks ago but it still had (albeit less frequent) issues with unexpected axis movements.
Matt
Postby RsX » Fri Jan 03, 2025 12:59 pm
v1.2117 solved it for me. I had the issue happening when the screen turned off and I pressed any button on the pendant.
Which version are you on and when does the issue occur?
RsX
Postby Matt » Mon Jan 13, 2025 11:25 am
I am also on 1.2117. The unexpected movements are better but not completely gone. So far it has only happened on my X axis since the update. Before it was happenings on all of XYZ. I'm questioning if it's some sort of electrical interference issue. Just out of curiosity, what are you using for a control board?
Matt
Postby RsX » Mon Jan 13, 2025 1:02 pm
I use an AXBB-E.
Do you have any buttons or another handwheel/keypad connected to the board?
The AXBB-E did give me false inputs, triggering the limit switches, and the signal debounce feature solved the issue.
RsX
Postby Matt » Fri Jan 17, 2025 1:22 pm
RsX wrote:I use an AXBB-E.
I don't knowingly have anything else wired in for direction or step signalling, but now I've got to go take a closer look on the chance one of the defaults had something setup for this. I'm running using a UC400ETH so for now at least I'll assume it's not as likely to be a hardware issue.
I was thinking it could be some feedback from a VFD but sometimes these movements happen when there is no active VFD.
The hunt continues!
Matt
