UCCNC crashing for me as well
Re: UCCNC crashing for me as well
Postby A_Camera » Mon Feb 13, 2017 8:27 pm
ger21 wrote:It's only on first use now, not every time.
Compiling every time UCCNC is started.
Postby cncdrive » Mon Feb 13, 2017 8:37 pm
You can disable that in the Configuration/General settings/Precompile all macros on startup checkbox.
If that checkbox is ticked then all macros are precompiled on startup.
If that checkbox is not ticked then the macros only compile on the first run once or if the macro text changed since the last compilation.
Postby cncdrive » Mon Feb 13, 2017 8:41 pm
It is though pity that it recompiles all the macro every time UCCNC is started. It should check the folder and if unchanged since last start it should not compile. It is a pretty simple operation to check the folder by calculating the checksum and save it when it is compiled and compare the checksum every time UCCNC is started. It is faster than compiling at every start.
Well, that's only an option.
If you do not choose that option then how it works now is it complies once when you execute the macro and only complies next time when the macro text is changed.
Ofcourse if you restart the UCCNC then everything resets.
The compiling to file can't work, because that would remove the ability to run the software in multiply instances, so is why we do not implement it that way, but I've mentioned this earlier in more details.
Postby A_Camera » Mon Feb 13, 2017 10:20 pm
Ok thanks for the explanation.
Postby A_Camera » Thu Feb 16, 2017 7:38 am
A_Camera wrote:I have done a few more tests. I can't force it to happen in 1.2030, so perhaps I was remembering all wrong and first time I have seen it may have been in 1.2031. On the other hand, it is easy to repeat in 1.2031 and in fact I made a video just to show what I do.
I can also easily repeat it on another computer, happens every time, or at least it seems so to me. Tested so far on two, one Dell desktop and one HP laptop.
Could it be connected to the actual pre-compilation message box? It was not implemented in 1.2030 only the compilation.
The video is now made private. No need to spread misinformation, since the issue is now fixed.
