New bug in 1.2041, or is it just my configuration?
Re: New bug in 1.2041, or is it just my configuration?
Postby dezsoe » Thu Jun 29, 2017 7:23 am
If you want to save your jog feed rate, use this in M99999.txt:
exec.Writekey("JogSettings", "JogFeedRate", AS3jog.Getfield(913));
and in M99998.txt:
AS3jog.Setfieldtext(exec.Readkey("JogSettings", "JogFeedRate", "10"), 913);
AS3jog.Validatefield(913);
Postby A_Camera » Thu Jun 29, 2017 8:40 am
dezsoe wrote:If you want to save your jog feed rate, use this in M99999.txt:
and in M99998.txt:
Yes, thanks, that's another possibility I was thinking about also, but then I realized that I mostly set it 30% so by changing it in the screen file to 30% it will be OK without involving macro calls.
Postby Greolt » Sat Sep 23, 2017 1:23 am
A_Camera wrote:Just solved it by changing this line in the Defaultscreenset.ssf:
AS3jog.Setfieldtext("10", 913);
Changed 10 to 30 and now it starts with 30%...
I made this change to 100, and now the "Jog Feed" DRO reads 100% upon startup.
However it still jogs at 10% untill I hit the + or - keys. After that it jogs at the rate shown on the DRO
EDIT: Added this line after the above,
Now it works.
Greolt
