The Probe sensor was active.
Re: The Probe sensor was active.
Postby kim@moltved.dk » Mon Jun 06, 2022 5:55 pm
Thangs :-)
kim@moltved.dk
Postby kim@moltved.dk » Mon Jun 06, 2022 7:04 pm
After update output port 5 pin 14 on my UC300ETH is not working, when downgrade it work.
kim@moltved.dk
Postby kim@moltved.dk » Tue Jun 07, 2022 6:07 pm
Just test with a total new installation with out changing anything, except for add the licens file.
Port 5, pin 14 i still activ and can be changed.
kim@moltved.dk
Postby cncdrive » Tue Jun 07, 2022 11:33 pm
Because what was fixed in this release was only the pendant based problems/probe sensor issue, nothing else.
Did you report your issue about port 5. pin 14. in the forum in a new topic or ...? If not then please do so.
Postby kim@moltved.dk » Wed Jun 08, 2022 6:24 am
Yes but the port 5 pin 14 is not a problem in the orginal 1.2115! So somthing is changed that made this problem!
kim@moltved.dk
Postby cncdrive » Wed Jun 08, 2022 6:49 pm
I don't think that we changed anything about it.
Maybe you configured more than one function to that pin.
Dezsoe, could you please verify this for me. Thanks.
Postby kim@moltved.dk » Wed Jun 08, 2022 8:03 pm
There is only 2 macros that use it that is start and stop 99998 99999. And both set it to low.
It even go in on state on a clean instalation. With default setup and macros. No setup!
kim@moltved.dk
Postby dezsoe » Wed Jun 08, 2022 9:49 pm
The bug exists. When the firmware update is ready pin 14 goes on. When I configured the M3 relay onto this pin then it worked, but when I zeroed out the M3 relay then it went wrong again.
Postby cncdrive » Thu Jun 09, 2022 6:26 am
Thanks Dezsoe, the API contains the new SPI bus communication function also for the UC300ETH which pins are on port#5, so the issue is probably caused by that.
We will check and correct it.
Postby kim@moltved.dk » Sun Jun 19, 2022 7:54 pm
Hi any update?
kim@moltved.dk
