Analog voltage bug?
Re: Analog voltage bug?
Postby ger21 » Fri Feb 04, 2022 3:14 pm
How are you changing the values of Var #6 and #7?
Postby tomsmith » Sat Feb 05, 2022 9:08 am
By the mdi
tomsmith
Postby fixebr » Sat Feb 05, 2022 3:57 pm
On your video, when you open the diagnostic tab, there are no numbers in the fields of analog inputs and outputs. This is not normal, there should be at least zeros.
fixebr
Postby dezsoe » Sat Feb 05, 2022 4:28 pm
Please, as always when reporting a bug, upload your profile.
Postby tomsmith » Sat Feb 05, 2022 5:14 pm
Hi guys, I just installed on a different pc and it seems to be working fine now, maybe it's an issue with the pc
tomsmith
Postby ger21 » Sat Feb 05, 2022 6:08 pm
As fixebr and cnc drive mentioned, there's an issue with the screen you are using.
Postby tomsmith » Tue Feb 08, 2022 2:54 pm
Thanks Gerry, Its working now so I'm going to leave it alone :?
tomsmith
