RUN and JOG Stay On After Homing
Re: RUN and JOG Stay On After Homing
Postby FactoryWorks » Thu Mar 17, 2022 11:06 pm
a few more things I have found. In searching this issue I came across a person who said they had the exact problem and once they unchecked the box for slaving A to Y (as they were not using a slave axis anyway) this problem went away. I tried it the same way, and verified it DOES fix the problem, however of course I need my slave stepper. I also found that after homing, if I move to 0,0 via the mdi there is no event- however once I jog it with the keyboard the event occurs again. This is easily replicatable and seems to be troubling a few people, not sure why it was so quickly ignored.
FactoryWorks
Postby DavidR8 » Sat Mar 19, 2022 3:32 pm
Is there any update on this issue @cncdrive
DavidR8
Postby cncdrive » Sat Mar 19, 2022 7:40 pm
Dezsoe, Please test this bug report.
Postby FactoryWorks » Sat Mar 19, 2022 9:01 pm
here is my .pro
4848RP.pro
(39.21 KiB) Downloaded 327 times
FactoryWorks
Postby dezsoe » Wed Mar 23, 2022 11:40 am
The bug exists using UC100, but not with UC400ETH. I tested with 1.2113 and 1.2116.
Postby dezsoe » Wed Mar 23, 2022 12:04 pm
I did some more tests. The problem exists with UC300 USB too, so it's related to the USB devices. Also, I found that the bug appears only if there is a homing backoff on the slave axis.
Postby johnsattuk » Wed Mar 23, 2022 7:51 pm
dezsoe wrote:The bug exists using UC100, but not with UC400ETH. I tested with 1.2113 and 1.2116.
1.2116 :D
Can't find it :(
johnsattuk
Postby FactoryWorks » Wed Mar 23, 2022 8:04 pm
Dezsoe, thank you for looking into this! As a workaround I set both my Y and A to 0 back off and it’s working great! I’m sure it will get figured out but the workaround is perfect for me.
FactoryWorks
Postby dezsoe » Wed Mar 23, 2022 9:38 pm
1.2116 :D
Can't find it :(
Yes, because it hasn't been released yet.
Postby Gebbi » Thu Mar 24, 2022 9:29 pm
dezsoe wrote:I did some more tests. The problem exists with UC300 USB too, so it's related to the USB devices. Also, I found that the bug appears only if there is a homing backoff on the slave axis.
Hi dezsoe,
thanks for that information.
I set back off to "0" --> there is no more problem :-)
I was no aware that there is a (very) small back off (allthoigh the value is "0") to get out of the end switch.
Gebbi
