1.2032 does not update firmware
Postby Derek » Tue Feb 07, 2017 10:26 pm
Just tried to test it out and it doesn't update the firmware.
Derek
EDIT:
UC300
Derek
Re: 1.2032 does not update firmware
Postby cncdrive » Tue Feb 07, 2017 10:32 pm
Hi Derek,
I think there is no new firmware for the UC300.
I don't remember any bugs which needed firmware change, but will ask my collegue tomorrow, he can confirm this.
Postby Derek » Tue Feb 07, 2017 10:49 pm
I tried to test the Q parameter for tapping. I did a test with one line with no Q and it went full depth the second line has a Q It makes the first Q pass, reverses and then sits with the spindle running. Like it's waiting for the index signal. I thought it might because of the firmware. But that doesn't make sense since it tried to do the Q. Any how I'm on 30140 FYI
Derek
Postby cncdrive » Tue Feb 07, 2017 11:13 pm
Could you please post that single line of code?
And you running this with the UC300-5LPT, the USB version, correct?
Postby Derek » Tue Feb 07, 2017 11:18 pm
UC-300 USB, M44B daughter board C-62 BOB
N17G33.1 Z-0.6250 K0.04167 Q.125
Derek
Postby cncdrive » Tue Feb 07, 2017 11:22 pm
OK, thanks Derek. It is over midnight here, so I'll test your code tomorrow to see what the problem is.
Postby Derek » Tue Feb 07, 2017 11:30 pm
cncdrive wrote:OK, thanks Derek. It is over midnight here, so I'll test your code tomorrow to see what the problem is.
Slacker. :)
Derek
Postby cncdrive » Tue Feb 07, 2017 11:31 pm
Derek 2 more questions I forgot to ask:
From what Z height did you start the tapping. (Z=0 ?)
And when the first pass finishes and when you say it is just sitting and waiting, if you open the Diagnostics page is the Sync.Thread LED still on?
I may be able to get to the problem cause without answers to these, but maybe I will need the answers, so I thought it is better to ask now, so tomorrow I will better know what to look for.
Slacker. :)
Postby Derek » Wed Feb 08, 2017 12:08 pm
Hi Balazs
Tapping starts .25" above work. After the tap reverses out of the hole and is at clearance height the Sync.thread LED is on and the CCW spindle LED is on. The spindle is turning CCW.
Derek
Users browsing this forum: sebba and 12 guests
