.net unhandled exception
Postby johu » Thu Apr 29, 2021 6:59 am
Today,
when first starting the application I got an error.
First the application showed a dialog message:
The software was started with the /s <SERIAL_NUMBER> command line argument, but a device with this serial number was not found.
Strange because the startup procedure was the same as always.
Directly after this I got an unhandled exception error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.OverflowException: Arithmetic operation resulted in an overflow.
   at USBClassLibrary.USBClass.GetUSBDevice(UInt32 VID, UInt32 PID, List`1& ListOfDP, Boolean GetCOMPort, Nullable`1 MI)
   at Plugins.PluginForm..ctor(UCCNCplugin Pluginmain)
   at Plugins.UCCNCplugin.Init_event(Entry UC)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4341.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
UCCNC
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/UCCNC/UCCNC.exe
System.Windows.Forms
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.8.4300.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
OpenTK
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.1664.6217
    CodeBase: file:///C:/UCCNC/OpenTK.DLL
System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
ୈỲ㬔䙸噤︬玿岱
    Assembly Version: 0.0.65535.65535
OpenTK.GLControl
    CodeBase: file:///C:/UCCNC/OpenTK.GLControl.DLL
OpenTK.Compatibility
    CodeBase: file:///C:/UCCNC/OpenTK.Compatibility.DLL
ILCalc
    Assembly Version: 0.9.7.5
ory3hwqa
    Assembly Version: 0.0.0.0
AForge.Video.DirectShow
    Assembly Version: 2.2.5.0
    Win32 Version: 2.2.5.0
    CodeBase: file:///C:/UCCNC/AForge.Video.DirectShow.DLL
Microsoft.CSharp
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
System.Dynamic
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
Anonymously Hosted DynamicMethods Assembly
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
j1j3bid1
Plugininterface
    CodeBase: file:///C:/UCCNC/Plugininterface.DLL
AutoBackupProfile
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/UCCNC/Plugins/AutoBackupProfile.dll
AutoLevelerCA
    CodeBase: file:///C:/UCCNC/Plugins/AutoLevelerCA.dll
C76 Fault Reporting
    CodeBase: file:///C:/UCCNC/Plugins/C76%20Fault%20Reporting.dll
Console
    CodeBase: file:///C:/UCCNC/Plugins/Console.dll
Debugger
    CodeBase: file:///C:/UCCNC/Plugins/Debugger.dll
Diagnostics
    CodeBase: file:///C:/UCCNC/Plugins/Diagnostics.dll
FaultSignals
    Assembly Version: 1.2.0.0
    Win32 Version: 1.2.0.0
    CodeBase: file:///C:/UCCNC/Plugins/FaultSignals.dll
Laserengrave
    CodeBase: file:///C:/UCCNC/Plugins/Laserengrave.dll
Lubricator
    CodeBase: file:///C:/UCCNC/Plugins/Lubricator.dll
Modbusmaster
    Assembly Version: 1.3.0.0
    Win32 Version: 1.3.0.0
    CodeBase: file:///C:/UCCNC/Plugins/Modbusmaster.dll
Pinout
    Assembly Version: 2.5.0.0
    Win32 Version: 2.5.0.0
    CodeBase: file:///C:/UCCNC/Plugins/Pinout.dll
Plugintest
    CodeBase: file:///C:/UCCNC/Plugins/Plugintest.dll
Printer3D
    CodeBase: file:///C:/UCCNC/Plugins/Printer3D.dll
Probing
    CodeBase: file:///C:/UCCNC/Plugins/Probing.dll
Profiler
    CodeBase: file:///C:/UCCNC/Plugins/Profiler.dll
Scope
    CodeBase: file:///C:/UCCNC/Plugins/Scope.dll
UCCAM
    CodeBase: file:///C:/UCCNC/Plugins/UCCAM.dll
UCCNC_OSK
    Assembly Version: 1.7.3.0
    Win32 Version: 1.7.3.0
    CodeBase: file:///C:/UCCNC/Plugins/UCCNC_OSK.dll
UCR200Plugin
    CodeBase: file:///C:/UCCNC/Plugins/UCR200Plugin.dll
UCR201Plugin
    CodeBase: file:///C:/UCCNC/Plugins/UCR201Plugin.dll
Webcamera
    CodeBase: file:///C:/UCCNC/Plugins/Webcamera.dll
Xbox360controller
    CodeBase: file:///C:/UCCNC/Plugins/Xbox360controller.dll
XHC-HB04_pendant
    CodeBase: file:///C:/UCCNC/Plugins/XHC-HB04_pendant.dll
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Although restarting the application fixed the problem, I still think the error should be handled properly.
johu
Re: .net unhandled exception
Postby cncdrive » Fri Apr 30, 2021 2:44 am
It is caused by one of the plugins you enabled.
But it is not clear which one caused it.
Postby johu » Wed May 12, 2021 9:45 am
I've had the "Unhandled Exception" multiple times now.
I'd like to figure out which plugin causes it.
The dialog box ends with:
enabled.
For example:
<configuration>
</configuration>
So I downloaded the Microsoft's "Visual Studio Community 2019" installer.
I've installed none of the "Workloads" and only selected the component "Just-In-Time debugger".
The installation size is approximatly 1.4Gb.
Now after a few restarts an "Unhandled Exception" popped-up:
Now it's clear where the error originated:
The UCR201 Plugin Beta 1.4
Now my question is:
Do you have a newer version of the plugin available?
- If yes, where to find it? (For now I've used the automatic installer from here)
- If no, could you enable the debugging feature for the application? Or should I enable something on my machine to make debugging work?
johu
Postby dezsoe » Wed May 12, 2021 10:50 am
Please, open the details and copy the detailed message here. Thanks.
Postby dezsoe » Wed May 12, 2021 10:52 am
And also your current profile, please. Maybe, it tries to load a bad setting.
Postby johu » Wed May 12, 2021 11:58 am
The UCR201 Pendant has FW V1.005
Europe CH: 2
The UCR201 Plugin is version Beta 1.4
My UCCNC profile is attached here:
CNC_Frees.pro
Profile
(42.24 KiB) Downloaded 616 times
And the details of the dialog:
mscorlib
UCCNC
System
System.Drawing
OpenTK
System.Core
System.Xml
ୈỲ㬔䙸噤︬玿岱
OpenTK.GLControl
ILCalc
fdal1szn
Microsoft.CSharp
System.Dynamic
5s4xdc5o
Plugininterface
AutoBackupProfile
AutolevelerCA
    CodeBase: file:///C:/UCCNC/Plugins/AutolevelerCA.dll
C76 Fault Reporting
Console
Debugger
Diagnostics
FaultSignals
Laserengrave
Lubricator
Modbusmaster
Pinout
Plugintest
Printer3D
Probing
Profiler
Scope
UCCAM
UCCNC_OSK
UCR200Plugin
UCR201Plugin
Webcamera
Xbox360controller
XHC-HB04_pendant
enabled.
For example:
<configuration>
</configuration>
johu
Postby Dimitris » Mon May 17, 2021 11:02 am
Hi to all,
I just received my UCR201 a couple of days ago. I love it!
The only problem I've got is that I get the unhandled exception when starting the UCNC application. Some times.. It takes a couple of retries to start successfully.
Dimitris
Postby dezsoe » Mon May 17, 2021 8:51 pm
Thank you for the details, I'll contact to the developer and be back soon.
Postby Battwell » Fri May 28, 2021 12:07 pm
i have had this with the ucr201 as well.
its resolved by unplugging and re mounting the usb receiver.
can be a pain!
Postby cncdrive » Sat May 29, 2021 1:06 am
Dezsoe, could you please check and correct his issue.
It seems to me that it is something to do with the HID devices query, but I do not have the source code nor a UCR201 at me to debug it.
So, please contact with the collegue who develops it and ask him to correct it or get the source code from him and correct it.
It would be nice to have this corrected in the next release.
