Axis keep jogging when reset is pressed
Postby berkenboom » Sun Mar 11, 2018 10:06 am
Hello, i am using uccnc version 1.2047 with the UC400ETH.
I was setting up jog/feedrates with my xbox controller (in demo mode) I found something strange:
When the override limit is active and I jog some axis (the x-axis in my case) with my xbox controller or keyboard, and i hit the reset button (while i am jogging) the reset state is activated but my axis keeps movingm even when i let go of the jog button. (eg key or xbox controller)
Its not possible to do some jogging when the machine is a reset state, so i assume this is a bug.
berkenboom
Re: Axis keep jogging when reset is pressed
Postby cncdrive » Sun Mar 11, 2018 10:26 am
This bug was already corrected in UCCNC test version 1.2103.
Copy from the release notes:
- In demo mode the reset did not stop the jog if the jog key was held down while triggering the reset. This could not cause an issue for any machines, because it only effected the demo modes which can't control a machine.
Postby berkenboom » Sun Mar 11, 2018 12:43 pm
Ah ok. Than i just have to wait until the new version comes out :)
berkenboom
Postby Haik » Mon Mar 12, 2018 7:46 am
The UCCNC beta download mentioned can be found in this forum at
http://www.forum.cncdrive.com/viewtopic.php?f=2&t=240&start=40#p8188
I hope this helps. :)
Haik
Postby ger21 » Mon Mar 12, 2018 10:43 am
The test version with the bug fix has been removed due to other bugs, so is not currently available.
Postby cncdrive » Mon Mar 12, 2018 3:39 pm
Gerry is correct. The test release 1.2103 was removed, because customers and also we explored some bugs which were introduced due to some of the upgrades in that release.
We currently working on fixing them and as soon as we will be ready then we will release a new test version.
