G31 Mach3
G31 Mach3
Postby Alberto FUL » Thu Jan 12, 2017 2:00 pm
Hello Balasz,
Mach 3 r. 1.043.66, UC300ETH5LPT, probe input 4/10.
I need to use the probe to check position of piece to work.
G91G31Z-20F100 (It is suppose not to trigger at this point, this is only approach)
The axis move but when the quote is achieved then it stops. Only if I hit the probe then it executesto the next operation.
I have same application but wit UC300USB and works perfectly.
Pugin 1.006 (tried right now 1.007 found on the forum but same problem).
Pls help
Alberto FUL
Alberto FUL
Re: G31 Mach3
Postby ger21 » Thu Jan 12, 2017 3:16 pm
Try Mach3 3.043.062.
Version .066 has issues with probing with other motion controllers.
Re: G31 Mach3
Postby Alberto FUL » Thu Jan 12, 2017 4:22 pm
Gerry,
Same behavior with 3.043.62.
It seems that it has to hit something anyway. It Waits until the probe input goes on.
Alberto FUL
Re: G31 Mach3
Postby Alberto FUL » Thu Jan 12, 2017 4:24 pm
UC300USB has no problem with 3.043.066
Neither UCCNC has problem with G31
Alberto FUL
Re: G31 Mach3
Postby cncdrive » Thu Jan 12, 2017 9:24 pm
This was fixed and test plugin posted in the duplicated thread: viewtopic.php?f=3&t=367
Users browsing this forum: Majestic-12 [Bot] and 22 guests
