Probe error message, “the machine was not yet homed”
Postby rgsteelebc » Sun Feb 07, 2021 11:25 pm
When i try using the “Probe Tool” in any mode I can use the buttons to set up the probe without any problem but when I click on start probe i get this message, “the machine was not yet homed”. I have homed the machine and the leds on the homing buttons are lit green. I have no problem with the “Simple Probe”. A response to the post below suggested that if i had a slave axis, which i do, using version 1.2113 would fix the problem. I installed that version and I still have the same problem.
viewtopic.php?f=3&t=2926
rgsteelebc
Re: Probe error message, “the machine was not yet homed”
Postby dezsoe » Mon Feb 08, 2021 6:53 am
Upload your profile (.pro) and I'll check it.
Postby rgsteelebc » Mon Feb 08, 2021 6:48 pm
Sorry false alarm It wasn't a bug after all. In setting up the slave axis A I also inadvertently checked the enable box on the B axis. Uncheck the enable box and it works great now.
rgsteelebc
Postby dezsoe » Mon Feb 08, 2021 11:06 pm
OK, fine!
